Other issues or features related to Microsoft Edge on Windows 11
how to stop edge from being managed by an organization I don't have? Just recently starting doing this...
I just used the suggestion they have me, to, "delete Microsoft Edge,," only I didn't reinstall it as suggested. I never used it, so I just deleted it all together and haven't had any problems since.
Is Fixlist.txt in the Downloads folder?
Thank you! Instead of running the command and deleting it altogether, I just changed the value of the HubsSidebarEnabled DWORD to 1 and pressed the "Reload Policies" button on the edge://policy/ page.
Whenever you see "managed by your organization" in Windows, it means that the setting or feature in question is setup in the Group Policy Editor rather than the Settings app. That's all it means.
Microsoft uses the wording "managed by your organization" because the Group Policy Editor is typically managed by the IT department in an organization. If you are not part of an organization, then you are your IT department. If that's the case, sign in to the Administrator account and search for: edit group policy
I'll offer this warning: The settings in the Group Policy Editor (they're actually called 'policies') can have far-reaching effects on your computer, so handle with care!
