how to stop edge from being managed by an organization
2023-04-19T22:49:23+00:00
how to stop edge from being managed by an organization I don't have? Just recently starting doing this...
Microsoft Edge | Other | Windows 11
    2023-09-06T07:11:09+00:00
    hello. my browser is being managed by an organization. in the edge policy it says Extensioninstallforcelist. i have tried everything i could and nothing worked. i cant change it and i dont know anything about electronics and i dont want to mess up my computer. please help! thank you
    2023-09-06T07:48:04+00:00
    You have probably been infected with malware. See _AW_'s reply on 29 June; I'm not sure if his script will also work for you, so I'll ask him to drop in and have a look.
  3. _AW_ 69,496 Reputation points Volunteer Moderator
    2023-09-06T10:47:59+00:00
    See if this clears things for you.
    • Type powershell into search and launch Windows Powershell as administrator.
    • Copy and paste in all the bold text below (both lines at once) into Powershell then press enter :
    reg delete HKLM\SOFTWARE\Policies\Microsoft\Edge\ExtensionInstallForcelist /f;reg delete HKCU\SOFTWARE\Policies\Microsoft\Edge\ExtensionInstallForcelist /f;
    • In Edge, enter edge://policy/ into the URL bar and press enter.
    • Click on 'Reload Policies'
    If ExtensionInstallForcelist is still present then you likely have malware.
    In that case, please upload and share logs from Farbar Recovery Scan Tool (FRST).
    https://www.bleepingcomputer.com/download/farbar-recovery-scan-tool/
    • If your computer language is not English, rename FRST64.exe to FRST64English.exe
    • Run FRST and press "Scan"
    • Two logs are created in the folder that FRST is run from, FRST.txt and Addition.txt
    • Upload the logs to OneDrive, Google Drive or any file sharing service
    • Post the share link
    Note: If you are downloading FRST with Edge, smartscreen will initially block it.
    Click on the 3 dots next to the warning and select Keep-> Show more-> Keep anyway.
  4. Deleted
  5. Deleted
