how to stop edge from being managed by an organization
2023-04-19T22:49:23+00:00
how to stop edge from being managed by an organization I don't have? Just recently starting doing this...
Microsoft Edge | Other | Windows 11
    2024-06-03T23:49:20+00:00
    This is what shows up when I go to the administration management section.
    2024-06-26T20:40:56+00:00
    Well, How?
    2024-07-10T20:16:23+00:00
    I'm not infected. I ran a scan using ZoneAlarm and it found no problems.
    ... if you see an entry on the page edge://policy that you don't recognize, please post back here with details.
    A screenshot of the page will do.
  4. _AW_ 69,496 Reputation points Volunteer Moderator
    2024-07-10T22:39:15+00:00
    Type powershell into search, then right click on Windows Powershell and "Run as administrator"
    Copy and paste in the following command -> press enter:
    reg delete HKCU\SOFTWARE\Policies\Microsoft\Edge /f;reg delete HKLM\SOFTWARE\Policies\Microsoft\Edge /f;
    Ignore any error as it's unlikely both keys exist.
    Paste edge://policy/ into the Edge Address bar -> press enter -> Click "Reload Policies"
    If the extension comes back, then the computer is still infected.
    2024-07-14T14:08:13+00:00
    Hello Fuz
    Im Juliet and Im happy to help you :)
    If your Microsoft Edge browser is being managed by an organization and you do not have access to manage it yourself, it is likely that your computer is connected to a work or school network that has policies in place to manage the browser. In this case, you may need to contact your network administrator for assistance.
    However, if you are using Microsoft Edge on a personal computer and it is being managed by an unknown organization, it may be a result of malware or a virus on your computer. In this case, you should run a full system scan with an up-to-date antivirus program and consider seeking the help of a professional if the issue persists.
    If you are simply experiencing issues with Microsoft Edge and want to reset the browser settings to their default values, you can follow these steps:
    1.Open Microsoft Edge and click the three-dot menu in the upper-right corner.
    2.Select "Settings" from the drop-down menu.
    3.Scroll down and click "Reset settings" under the "Reset and cleanup" section.
    4.Click "Restore settings to their default values" and then click "Reset."
    5. Restart Microsoft Edge and check if the issue has been resolved.
    I hope this helps! Let me know what happens :)
    i have done everything. BUT STILL ITS SHOWING .
    I HAVE SAFTY CHECKS NO MALWARE WAS FOUND ....
    " ExtensionManifestV2Availability " THIS IS SHOWING
