Installing or updating Microsoft Edge on macOS
* * Locked * *
Can you download Edge Browser to a Chromebook? And if yes, how? I really appreciate your help. :-)
Hi Crystal,
I am Sumit, an Independent Advisor and a 2-Year Windows Insider MVP here to help.
You can run Android apps on Chromebook so I believe you can run Microsoft Edge..
Install Android apps on your Chromebook - Chromebook Help
https://support.google.com/chromebook/answer/70...
Microsoft Edge – Apps on Google Play
https://play.google.com/store/apps/details?id=c...
The experience would not be same as desktop, though.
Disclaimer:
There are links to non-Microsoft websites which would provide accurate and safe information. Watch out for ads on the websites which are frequently classified as a PUP (Potentially Unwanted Products). There is no need to buy paid products to fix your computers as they do more harm than good sometimes.
I followed the link to Edge on Google play. I got a message saying that it was not compatible. I'm running Chrome 80.0.3987.67 Any Ideas?
I own the latest (I think) Asus Flip C302C Chromebook and have found that many common Android apps are not compatible with it. They'll work on many phones but often few Chromebooks.
