Download Edge Browser for Chromebook
2019-08-03T14:57:01+00:00
* * Locked * *
Can you download Edge Browser to a Chromebook? And if yes, how? I really appreciate your help. :-)
Microsoft Edge | Install and update | MacOS
SD - IA 179.6K Reputation points Independent Advisor
2019-08-03T14:59:34+00:00
Hi Crystal,
I am Sumit, an Independent Advisor and a 2-Year Windows Insider MVP here to help.
You can run Android apps on Chromebook so I believe you can run Microsoft Edge..
Install Android apps on your Chromebook - Chromebook Help
https://support.google.com/chromebook/answer/70...
Microsoft Edge – Apps on Google Play
https://play.google.com/store/apps/details?id=c...
The experience would not be same as desktop, though.
Disclaimer:
There are links to non-Microsoft websites which would provide accurate and safe information. Watch out for ads on the websites which are frequently classified as a PUP (Potentially Unwanted Products). There is no need to buy paid products to fix your computers as they do more harm than good sometimes.
89 additional answers
    2021-02-13T00:24:27+00:00
    it's actually really easy. I have written about this topic on my blog and fully tested the method personally. This post is from Jan 30th 2021, so it should still work. here you go:
    Microsoft Edge on A Chromebook
  2. Deleted
  3. Deleted
    2021-02-25T13:28:33+00:00
    give for chroom book edge brawser
