Installing or updating Microsoft Edge on macOS
* * Locked * *
Can you download Edge Browser to a Chromebook? And if yes, how? I really appreciate your help. :-)
Hi Crystal,
I am Sumit, an Independent Advisor and a 2-Year Windows Insider MVP here to help.
You can run Android apps on Chromebook so I believe you can run Microsoft Edge..
Install Android apps on your Chromebook - Chromebook Help
https://support.google.com/chromebook/answer/70...
Microsoft Edge – Apps on Google Play
https://play.google.com/store/apps/details?id=c...
The experience would not be same as desktop, though.
Disclaimer:
There are links to non-Microsoft websites which would provide accurate and safe information. Watch out for ads on the websites which are frequently classified as a PUP (Potentially Unwanted Products). There is no need to buy paid products to fix your computers as they do more harm than good sometimes.
NGL_GamerGod972 wrote: How do you install and enable google play store? - - There's nothing to install. Access Google Play at https://play.google.com/store Edge for Android https://play.google.com/store/apps/details?id=com.microsoft.emmx
Don
People! Microsoft Edge is not in the Chromebook Play Store!
