Launching Microsoft Edge on Windows 10
I have just updated to the new Edge (Chrome Look-alike).
When using the "old" Edge, it would automatically open when I clicked on a URL. All was fine.
With the "New" Edge, when you click on a link it sits in the task bar flashing at you. You then have to click on the flashing icon to open up Edge.
I find this very annoying and would like to know if there is a way to remedy this so that it automatically opens again.
If this is how the "New" Edge is supposed to operate, then I think it is a backward step and not progressive.
Pedro
* Original title: Microsoft Edge
I have the same flashing taskbar issue, Edge-new is my default and I do not use Mail, I use Outlook. So what's my problem?
H Charliesbutterfly
Your problem is the flashing Edge in the taskbar.
Seriously - I uninstalled New Edge, changed from Mail to Outlook and then reinstalled New Edge as my default browser. Make sure you update/check for updates for the New Edge.
I have not had a problem since.
Pedro
If you read all the posts, there is no one reason why there is a flashing icon because everyone has tried a combination of the variables mentioned. They appear to be; Outlook, Mail, Edge, etc.
Charles and Pedro seem to have the same setup yet one still has flashes. I think those like me with Mail will always have that a problem.
Of topic-I would have gotten a program with Outlook but did not know they dropped OCR from 2019 and only wanted Word at the time. I did not expect this flimsy Mail which is insecure and flawed.
Hi Peter D. N.
I sympathize with you.
Yep I have Office 2010 on my laptop and Office Pro 2016 on Desktop and it is this that Outlook is included.
I check all of my emails on my desktop now. Sorry I can't be of further help.
When I did move to Outlook I was still having problems until I deleted and then re-installed the New Edge and installed updates that were available for it. Now no problems,
Pedro
Thanks Pedro.
I either break down and buy Outlook or live with Mail but at least this nagging issue is resolved.
It is not a big issue but I wondered why Mail acted that way and if there was a fix.
You know what you get for nothing.
Tenga un buen día.
Otra Pedro :)
