When I click on a URL Edge opens minimized on the Taskbar and flashing
2020-01-22T05:23:36+00:00
I have just updated to the new Edge (Chrome Look-alike).
When using the "old" Edge, it would automatically open when I clicked on a URL.  All was fine.
With the "New" Edge, when you click on a link it sits in the task bar flashing at you.  You then have to click on the flashing icon to open up Edge.
I find this very annoying and would like to know if there is a way to remedy this so that it automatically opens again.
If this is how the "New" Edge is supposed to operate, then I think it is a backward step and not progressive.
Pedro
* Original title: Microsoft Edge
Microsoft Edge | Open the browser | Windows 10
    2020-01-22T06:16:56+00:00
    Hi Pedro. I'm Greg, an installation specialist and 9 year Windows MVP, here to help you.
    This is not how it's supposed to work. My links in new Edge open in the same tab by default.
    If yours is different then for New Edge try resetting it Edge Settings > Reset to Defaults, or for Old Edge in Settings > Apps > Apps & Features > Edge > Advanced Features.
    If that's not enough re-register Edge from Option 2 here: http://www.tenforums.com/tutorials/3175-apps-re...
    And if that fails uninstall Edge in App settings above, restart PC, then reinstall from MS Store > My Library.
    I hope this helps. Feel free to ask back any questions and keep me posted. I will keep working with you until it's resolved.
    ________________________________________________________
    2020-01-22T08:31:56+00:00
    Hi Greg
    Thanks for your response.  I followed your instructions and ended up deleting Edge.
    I am now back to the "Old" Edge.
    The "new" Chromium based version which became available on the 15 Jan. just refused to open in the manner in which it should have.
    Will wait and see if there is an automatic update further into the year.
    Pedro
  3. Deleted
    2020-01-22T17:18:02+00:00
    Hi Pedro -
    Did you try resetting new Edge? If not try reinstalling it from here:
    https://www.microsoft.com/en-us/edge
    If reinstalling doesn't fix it then try resetting it in Edge Settings > Reset Settings, and also from Windows Settings > Apps > Apps & Features > Edge > Advanced Options > Reset.
    2020-01-23T03:07:01+00:00
    Hi Greg
      Still no luck.  It worked a couple of times and then back to usual - just sitting in the task bar blinking.  When I click on it in the task bar, it opens with the site I had selected.
    I have been through all you have suggested, however, in Edge settings I don't have Advanced Features anywhere.
    I have thrown in the towel and reverted back to the old Edge.  No problems with that one.
    many thanks.
    A very frustated
    Pedro
