Troubleshooting browser crashes or performance issues on Windows 11
Edge keeps crashing in Windows 11. I have already tried quite a few troubleshooting steps suggested here and it's still not fixed. The last suggestion I received before reinstalling Windows is to reinstall Edge. (Not repair/reinstall from the Add/Remove Programs menu, I've already tried that). I did this but it doesn't look like it worked. When I opened Edge after the reinstall all my tabs re-opened and I just don't think the reinstall worked correctly. Is there a way to uninstall Edge completely and then reinstall it? The option is grayed out in the Remove programs menu.
I have found that booting into windows safe mode allows me to delete all of Microsoft edge (folders are in C:\Program Files(x86)\Microsoft). While this is technically not the "right" way, it does allow you to remove it (even in file explorer)!
I realize this is a dated article... I am trying to uninstall and reinstall Edge - have suddenly started experiencing odd issues. I run the script as suggested using PowerShell. I am not receiving any errors however I am instantly returned to the prompt and nothing appears to have happened. Have the setup.exe parameters changed in the latest versions of Edge? The new Application sub-directory is now "131.0.2903.112".
Thanks!
