How to Uninstall/Reinstall Edge
2023-01-27T21:57:04+00:00
Edge keeps crashing in Windows 11. I have already tried quite a few troubleshooting steps suggested here and it's still not fixed. The last suggestion I received before reinstalling Windows is to reinstall Edge. (Not repair/reinstall from the Add/Remove Programs menu, I've already tried that). I did this but it doesn't look like it worked. When I opened Edge after the reinstall all my tabs re-opened and I just don't think the reinstall worked correctly. Is there a way to uninstall Edge completely and then reinstall it? The option is grayed out in the Remove programs menu.
Microsoft Edge | Browser crashes or stops working | Windows 11
    2024-11-18T08:16:41+00:00
    I have a problem Uninstaller with microsoft Edge it will not be removed and re-installed what I am I to do as of now I haven't got a browser it's a windows 11pro for quite a while now I have tried to fix it I was to uninstall EDGE then reinstall EDGE but I am unable to uninstall my copy of it so I have no Edge so no browser what is most important option. The problem started with my first EDGE disappeared after my last update from the Microsoft updates so what can be done THIS IS MICROSOFT 11pro as of now it's just a paper wait with no purpose it is only 6months ******@aol.com. Willam Ian Gray.
    2024-11-18T18:28:33+00:00
    When I tried to use these directions I received this message:
    PS C:\Program Files (x86)\Microsoft\EdgeUpdate\Install> .\setup.exe -uninstall -system-level -verbose-logging -force-uninstall
    .\setup.exe : The term '.\setup.exe' is not recognized as the name of a cmdlet, function, script file, or operable
    program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
    At line:1 char:1
    • .\setup.exe -uninstall -system-level -verbose-logging -force-uninstal ...
    •     + CategoryInfo          : ObjectNotFound: (.\setup.exe:String) [], CommandNotFoundException
          + FullyQualifiedErrorId : CommandNotFoundException
    2024-11-18T20:51:27+00:00
    I've learned a few things since I first posted this question. The one thing I've learned that really matters here is that Windows 11 requires Edge as it uses it as the base for its GUI. Because of this, Windows won't function if Edge is not installed. So, if you want to remove Edge, just remove Windows 11. Also, that's why you (and the rest of us) get an error when we try to use the Command prompt or Power Shell to make changes to it or remove it.
    Like the rest of us, you're just going to have to learn to ignore it until Microsoft actually makes it worth using. Yeah, the content they put on their pages, etc absolutely sucks.
    2024-11-18T20:58:21+00:00
    If I were you, I'd run the System File Checker with the /scannow option to see if it will fix the Edge installation for you. If you can, go check this post out for instructions on how to fix it from a Powershell command prompt:
    https://answers.microsoft.com/en-us/windows/forum/all/will-sfc-scannow-fix-the-system-files-in-win-11-as/0454dc2b-10b4-4544-805f-5e00f2d7455d
    I' m assuming you have a working browser if you're reading this and posting here so...
    Good luck
    2024-11-22T20:56:02+00:00
    From my guru tech -
    Did everything up to the PowerShell part, that errored out for me
    So, I had to search for setup.exe (it was in a Microsoft WoW directory) and copy it to the 'Application' directory.
    Then I deleted all folders within the Program File (x86)/Microsoft/Edge directory (including the Edge directory).
    Then I went to Apps and Features and ran a repair on Edge. It had to download it clean and it worked!
    UPDATE 11/22/2024 - Microsoft looks like they fixed their problem with Edge version *.63 being installed today.
    Yay. Thanks for the stress exercise.
