Microsoft Edge keeps closing soon after opening. This is occurring after their most recent update was automatically installed around 2/10/2023. Why is this occurring?
2023-02-12T03:25:19+00:00
Microsoft Edge | Browser crashes or stops working | Windows 10
    2023-02-20T10:53:33+00:00
    Hi Bernard,
    It is more serious that a fix you described. It occurs on my Windows 10 PC as well as my iPad Pro11 and my iPhone 12. There is definitely something wrong with Edge. It is now unusable.
    Regards,,
    Greg
    2023-02-12T05:26:56+00:00
    2023-02-12T04:23:24+00:00
    Hi and thanks for reaching out. My name is Bernard a Windows fan like you. I'll be happy to help you out today.
    I understand the issue you have, nothing to worry I am here to help, we need to re-calibrate the edge and repair it so that we can fix the issue, kindly follow the steps below:
    Method 1. Repair Microsoft Edge
    Go to Settings > Apps > Apps & Features
    Scroll down and look for Microsoft Edge
    Click on Edge> Click Modify
    Then follow the prompts to repair.
    Method 2. Repair Windows Store and apps (Such as Edge):
    On Powershell(admin), copy and paste the command below:
    Get-AppXPackage | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
    Then hit Enter, once the process is done, restart the PC and check.
    Method 3. repair Windows Store and update components
    Open Powershell with Admin or CMD with Admin (Press Windows key + X then click Windows Powershell(Admin))
    Copy each line of command to Powershell then press enter (one line at a time)
    net stop bits
    net stop wuauserv
    net stop appidsvc
    net stop cryptsvc
    Del "%ALLUSERSPROFILE%\Application Data\Microsoft\Network\Downloader\*.*"
    rmdir %systemroot%\SoftwareDistribution /S /Q
    rmdir %systemroot%\system32\catroot2 /S /Q
    regsvr32.exe /s atl.dll
    regsvr32.exe /s urlmon.dll
    regsvr32.exe /s mshtml.dll
    netsh winsock reset
    netsh winsock reset proxy
    net start bits
    net start wuauserv
    net start appidsvc
    net start cryptsvc
    -Once done restart the device and check.
    Let me know how it goes and I hope that helps.
    Bernard
