Opening and reading PDF files in Microsoft Edge on Windows 10
How do I stop Microsoft edge from opening? everytime I do the system performance check from dell it sets up Microsoft edge to open PDF files and I have my own program I use, however I cant set it as my default program....
* Original title: Microsoft Edge
Thank you for writing to Microsoft Community Forums.
We understand your concern as you would like to change the default app for PDF file from Edge to Adobe.
In this scenario, we would suggest you to perform these methods and check.
Method 1: Change the setting for Apps
Method 2: Stop opening PDF file if you are using New Edge Chromium.
Notes: If the Always open PDF files externally is on then if you try to open any online PDF document, it will prompt you to download and later you can use Adobe Reader to view.
Regards,
Aditya Roy
Microsoft Community – Moderator
Adobe Acrobat professional is not changing the default app.
It was in 2018 that Windows tightened up the file association protection measures that you seem to be running into. I can't find documentation for this, but versions newer than Acrobat Pro DC 18 shouldn't be doing this. It's likely that Acrobat Pro 2017 writes to registry keys that only users are allowed to change (by using the default apps settings available).
Could it be that you're using an older version of Acrobat?
That answers a question you weren't asked.
The question is: how do we stop Microsoft Edge changing the default app for opening PDFs without permission?
Thank you. Your advice was very helpful.
That option is not available:
I can choose: 'Always download PDF files' or 'PDF view settings
This is not good - I normally use Windows 7 and PDF files open in Adobe but I have tried to like Windows 10 but it's issues like this that prevents me. I'm not new to Windows and go right back to Win 3.11. I've used most versions of Windows and without doubt Win 10 is the worst. It's an absolute nightmare to use and I'm thinking of learning Linux
