Opening and reading PDF files in Microsoft Edge on Windows 10
How do I stop Microsoft edge from opening? everytime I do the system performance check from dell it sets up Microsoft edge to open PDF files and I have my own program I use, however I cant set it as my default program....
* Original title: Microsoft Edge
Thank you for writing to Microsoft Community Forums.
We understand your concern as you would like to change the default app for PDF file from Edge to Adobe.
In this scenario, we would suggest you to perform these methods and check.
Method 1: Change the setting for Apps
Method 2: Stop opening PDF file if you are using New Edge Chromium.
Notes: If the Always open PDF files externally is on then if you try to open any online PDF document, it will prompt you to download and later you can use Adobe Reader to view.
Regards,
Aditya Roy
Microsoft Community – Moderator
Adobe Acrobat professional is not changing the default app.
It was in 2018 that Windows tightened up the file association protection measures that you seem to be running into. I can't find documentation for this, but versions newer than Acrobat Pro DC 18 shouldn't be doing this. It's likely that Acrobat Pro 2017 writes to registry keys that only users are allowed to change (by using the default apps settings available).
Could it be that you're using an older version of Acrobat?
FYI - Method 2 doesn't work for Microsoft Edge. I have tried it multiple times.
Plus the switch doesn't say open file PDF files externally. It says:
"Always download PDF files
Download PDF files to your device. If Microsoft Edge is your default PDF reader, PDF files will open automatically without downloading."
And it does automatically download if you toggle it but into the PDF Microsoft Edge browser. I want it to open the actual program so I can have thumbnails of the pages. That way I can drag one page to another PDF without having to save the PDF first and going back to delete the document after I have add the page to the other PDF.
what if users do not use Adobe software for PDFs ... windows 10 will Not honor default setting
This doesnt work for me either, and the instructions dont quite match up with my options. I switched from a Mac to a PC and generally feel it is easier to navigate, but the constant manipulation by Microsoft to force behavior is really bizarre and shows how insecure Microsoft is about its ideas and products. The vast majority of people who want to open a PDF want to open it in the most common and best PDF viewer people have used since the beginning of time, Adobe. Why wont you just easily let us NOT HAVE TO answer YES to using Edge automatically? Why is there not a "NO" option?!?!?!?!?!? This is insane and it is insulting. Every time i think I'll give Edge a try again, I regret it. Switching back to Firefox, they dont pester you with annoying forced ****.
