Opening and reading PDF files in Microsoft Edge on Windows 10
How do I stop Microsoft edge from opening? everytime I do the system performance check from dell it sets up Microsoft edge to open PDF files and I have my own program I use, however I cant set it as my default program....
* Original title: Microsoft Edge
Thank you for writing to Microsoft Community Forums.
We understand your concern as you would like to change the default app for PDF file from Edge to Adobe.
In this scenario, we would suggest you to perform these methods and check.
Method 1: Change the setting for Apps
Method 2: Stop opening PDF file if you are using New Edge Chromium.
Notes: If the Always open PDF files externally is on then if you try to open any online PDF document, it will prompt you to download and later you can use Adobe Reader to view.
Regards,
Aditya Roy
Microsoft Community – Moderator
Adobe Acrobat professional is not changing the default app.
It was in 2018 that Windows tightened up the file association protection measures that you seem to be running into. I can't find documentation for this, but versions newer than Acrobat Pro DC 18 shouldn't be doing this. It's likely that Acrobat Pro 2017 writes to registry keys that only users are allowed to change (by using the default apps settings available).
Could it be that you're using an older version of Acrobat?
This problem has nothing to do with an end user's choice of default program to open PDF's or Images, and everything to do with prior Windows update. The file(s) that is continuously changing the end user default for handling PDF's (and Photos) is: OEMDefaultAssociations DLL and XML.
This is the file that will continually override the end user's choice for default PDF program. Microsoft is doing all it can to show how handy MS Edge is - and part of that 'doing' is adding code to Windows that automagically changes the default programs to Microsoft-selected defaults.
This has nothing to do with protecting Windows, and everything to do with promoting Edge over your choice of default PDF and Image programs. Just look at the code that is inside the OEMDefaultAssociations files.
Here's the section that forces Windows to use MS Edge to open PDF files:
<Association Identifier=".pdf" ProgId="AppXd4nrz8ff68srnhf9t5a8sbjyar1cr723" ApplicationName="Microsoft E ApplicationName="Microsoft Edge" ApplyOnUpgrade="true" OverwriteIfProgIdIs="AppXk660crfh0gw7gd9swc1nws708mn7qjr1;AppX86746z2101ayy2ygv3g96e4eqdf8r99j" />
And this is the section that forces Windows to use MS Photo or Paint to open JPG files:
<Association Identifier=".jpg" ProgId="AppX43hnxtbyyps62jhe9sqpdzxn1790zetc" ApplicationName="Photos" ApplyOnUpgrade="true" OverwriteIfProgIdIs="AppX9vdwcvrwnbettpahnt26jswq0n8hgyah;Paint.Paint;Microsoft.PhotoManager.imagetype;jpegfile" />
Every time you change the default back to your desired program(s), within minutes or hours, this Windows XML (and DLL) will change the defaults..without your permission. This can occur multiple times each day.
And note: None of the info you provided is valid any more. Once Microsoft allowed this malicious DLL and XML file onto our computers, the Windows standard process of changing the default programs was completely ruined.
When Microsoft changes these files and removes the forced override of our choices, the problem will end.
Is there any possibility of you running this past the Windows group?
But you don't realize, its NOT the program that is trying to change the user-configured defaults, I, the user, am changing the program defaults. It is Windows or Edge that is changing the default assignment that I have made in in Windows Settings, back to Edge. Adobe Acrobat is not trying to change the default assignment. As identified by "the pc doc' in a previous post, the windows file that is continuously changing the default assignment back to Edge is OEMDefaultAssociations DLL and XML.
From "the pc doc''s post:
This is clearly a Microsoft attempt to make everybody use their programs, which is in violation of the anti-trust consent decree with the US Justice Department that was mandated in 2002. Unfortunately, the consent decree stipulated that they only had to obey the antitrust laws for 5 years, then they are free to do whatever they want. It was later extended to 2011, but then the Justice Department let it expire.
OEMDefaultAssociations DLL and XML. ... is the file that will continually override the end user's choice for default PDF program.
I've seen you post this passage before, but I'm not sure that what you claim is completely accurate. For example, I installed Paint.NET in November 2020 and set it as the default handler for most image types. The machine was then on Windows 10 20H2 and is now on 21H1. I have used several different programs to edit images during this period, including Paint and Paint 3D. Paint.NET remains the default photo viewer, so the reversion to Photos that you mention hasn't happened for me.
I think the OEM... files should only run at user sign-in, so there's no reason why they should "change the defaults..without your permission ... multiple times each day." This is where the Windows 'recommended' apps are specified, but as far as I am aware the XML can't (successfully) be modified to alter its behaviour.
