How do I stop Edge from opening PDF files?
2020-04-16T12:40:17+00:00
How do I stop Microsoft edge from opening? everytime I do the system performance check from dell it sets up Microsoft edge to open PDF files and I have my own program I use, however I cant set it as my default program....
* Original title: Microsoft Edge
Microsoft Edge | Read PDFs | Windows 10
2020-04-17T08:41:58+00:00
Thank you for writing to Microsoft Community Forums.
We understand your concern as you would like to change the default app for PDF file from Edge to Adobe.
In this scenario, we would suggest you to perform these methods and check.
Method 1: Change the setting for Apps
  1. Press Windows + I key to launch Windows Settings.
  2. Click on Apps and select Default apps from the left pane.
  3. Now scroll down and click on Choose default apps by file type.
  4. Scroll and look for .pdf, .pdxml, and .pdx file type, then click on the + sign to change it to Adobe Reader.
Method 2: Stop opening PDF file if you are using New Edge Chromium.
  1. Open Microsoft Edge
  2. Click on the three dots (…) from the right top corner.
  3. Select Settings from the drop down and click on Site permissions from the left pane.
  4. Scroll down and click on PDF documents, Toggle the switch to On for Always open PDF files externally.
Notes: If the Always open PDF files externally is on then if you try to open any online PDF document, it will prompt you to download and later you can use Adobe Reader to view.
Regards,
Aditya Roy
Microsoft Community – Moderator
2020-08-14T08:06:25+00:00
Adobe Acrobat professional is not changing the default app.
It was in 2018 that Windows tightened up the file association protection measures that you seem to be running into. I can't find documentation for this, but versions newer than Acrobat Pro DC 18 shouldn't be doing this. It's likely that Acrobat Pro 2017 writes to registry keys that only users are allowed to change (by using the default apps settings available).
Could it be that you're using an older version of Acrobat?
161 additional answers
    2021-04-01T19:49:04+00:00
    Regards,
    Aditya Roy
    And yet every time there is slightest Win10 update a new EDGE appears and overwrites the default .PDF file settings. If I had 100 copies of EDGE or EDGE+ installed on my computers - I would never ever want to use it to open any PDF files. You need to stop this ****, because EDGE leaves me on edge!!!
    2021-04-01T20:16:16+00:00
    It doesn't even need an update, Often Edge will steal back the pdf assignment within an hour or two.  Sometimes as fast as 5 minutes.
    2021-04-01T20:23:51+00:00
    Just had my IT firm disable Edge entirely.
    Any bets as to whether it comes back and hijacks the default settings on the next update?
    Microsoft is also advertising Edge like crazy on Reddit -- and disabling the comments.
