Opening and reading PDF files in Microsoft Edge on Windows 10
How do I stop Microsoft edge from opening? everytime I do the system performance check from dell it sets up Microsoft edge to open PDF files and I have my own program I use, however I cant set it as my default program....
* Original title: Microsoft Edge
Thank you for writing to Microsoft Community Forums.
We understand your concern as you would like to change the default app for PDF file from Edge to Adobe.
In this scenario, we would suggest you to perform these methods and check.
Method 1: Change the setting for Apps
Method 2: Stop opening PDF file if you are using New Edge Chromium.
Notes: If the Always open PDF files externally is on then if you try to open any online PDF document, it will prompt you to download and later you can use Adobe Reader to view.
Regards,
Aditya Roy
Microsoft Community – Moderator
Adobe Acrobat professional is not changing the default app.
It was in 2018 that Windows tightened up the file association protection measures that you seem to be running into. I can't find documentation for this, but versions newer than Acrobat Pro DC 18 shouldn't be doing this. It's likely that Acrobat Pro 2017 writes to registry keys that only users are allowed to change (by using the default apps settings available).
Could it be that you're using an older version of Acrobat?
Why should I pay thousands of dollars over the coming years for new software, when I am perfectly happy with software that I have already purchased and own. I wonder how much of a kick back Microsoft gets from Adobe for doing this. Because doing this does not help Microsoft at all. Edge is the most lame PDF client on the market. It just makes them look bad. The kick back must be substantial. Adobe's official stance is that this problem does not exist, and we are all imagining it. Right!
Hi
Acrobat REader DC is completly FREE
Don
Don,
Yes I know but I need more than a reader. Acrobat Reader DC is a PDF viewer that lets you read, search, print, and interact with virtually any type of PDF file.
I wanted the whole thing and the Adobe Acrobat DC is perfect. Today I found more things I can do with it than with Nuance Power PDF Standard.
All is good and thanks!
