Opening and reading PDF files in Microsoft Edge on Windows 10
How do I stop Microsoft edge from opening? everytime I do the system performance check from dell it sets up Microsoft edge to open PDF files and I have my own program I use, however I cant set it as my default program....
* Original title: Microsoft Edge
Thank you for writing to Microsoft Community Forums.
We understand your concern as you would like to change the default app for PDF file from Edge to Adobe.
In this scenario, we would suggest you to perform these methods and check.
Method 1: Change the setting for Apps
Method 2: Stop opening PDF file if you are using New Edge Chromium.
Notes: If the Always open PDF files externally is on then if you try to open any online PDF document, it will prompt you to download and later you can use Adobe Reader to view.
Regards,
Aditya Roy
Microsoft Community – Moderator
Adobe Acrobat professional is not changing the default app.
It was in 2018 that Windows tightened up the file association protection measures that you seem to be running into. I can't find documentation for this, but versions newer than Acrobat Pro DC 18 shouldn't be doing this. It's likely that Acrobat Pro 2017 writes to registry keys that only users are allowed to change (by using the default apps settings available).
Could it be that you're using an older version of Acrobat?
This is great, except, i have to do it multiple times per day. Is there no way to permanently murder Microsoft edge? I will never use it - especially after contending with this all the time. I really don't appreciate a program taking over my computer over and over.
I have read through many of the responses and wondered if any have tried this one. I tried it, it works! I even restarted my computer and again no issues. I hope the link is helpful to many. I do design and drafting and PDF's are used extensively between clients, engineers and for submitting plan sets for building permits.
I was getting really mad when I had purchased Power PDF Standard which I have used for a long time. For my purposes, it works great. So here you are with Microsoft Edge that hijacks the ability to use my desired program. I changed the default app to Power PDF Standard but it would only last a day if that, when I want to open a PDF I have to right click and select "Open with etc"! Irritating and time consuming.
I use Chrome and Firefox and have Win 10. I have mostly good things to say about Microsoft but (you know what I mean).
Try this and see if it has the results you want to achieve.
Hi
There are 2 options that I know of
Download and Install BLUESKY Browser and make it your default
Or change to Linux Distro System.
I use Linux Mint and it works great
Regards
Don Henry
