Installing or updating Microsoft Edge on Windows 10
I set up loaner devices to just use the browser. I recently updated them to Windows10-2004 and installed the new Edge browser. I just get a blank blue screen when I try to sign in with kiosk mode after setting it up to open with Edge (the Icon that I am able to select still looks like the old one). Does anyone know if I need to go back to the old OS or the old Edge?
When i set up kiosk, only a blue screen plays, not my url. When i use the start up command, it keeps asking me to log in first! How do i remove the log in page? Please help!
Hi Sue_552, thanks for reaching out! The blue screen might indicate that you installed the new Microsoft Edge on the Stable channel and it replaced your legacy version of Microsoft Edge.
For the new Microsoft Edge kiosk mode configuration please refer to: https://docs.microsoft.com/en-us/deployedge/microsoft-edge-configure-kiosk-mode
Note: This applies to new Microsoft Edge versions 87 and up. You can download Microsoft Edge Insider builds from the Microsoft Edge Insider Channels page.
I'd love to work with you to help set up your kiosk. If downloading and trying one of the Insider channels doesn't resolve this issue, could you provide the following information:
Thanks again for reaching out and let us know if you have any other questions about kiosk mode! -Alex
Thanks for your quick response... Here are my replies
Another issue I noticed is that my url playing via start up command will suddenly magnify on the screen display, so that only part of the page is visible. It did this when I checked edge://settings too.... suddenly the page was "zoomed in" huge.
Thanks for the responses!
Kiosk mode is enabled for Microsoft Edge versions 87 and up. Kiosk mode is currently available on our Insiders Beta channel and is planned for release to our Stable channel (the default channel and the one you're using based on your version number) later this month. You can check for updates to the release schedule here: https://docs.microsoft.com/en-us/DeployEdge/microsoft-edge-release-schedule
Also, check out this doc for some command line options and information on Assigned Access, which is currently only available in the Dev Channel: https://docs.microsoft.com/en-us/deployedge/microsoft-edge-configure-kiosk-mode#use-kiosk-mode-features
If you're still seeing that zooming issue after updating to version 87, let us know!
Please let me know if you have any additional questions!
-Alex
Hi again,
When I try to update Edge it says version 86.0.622.63 IS up to date. Why doesn't it go to version 87?
