Launching Microsoft Edge on Windows 10
How can I stop Microsoft Edge from starting every time I restart my computer?
**Updated for clarity**
Hello JosephPare1,
I'm John an Independent Advisor and a Microsoft user like you. I'll be happy to assist you today. I understand you have a problem with Edge opening automatically at startup. Did you made any changes recently? When was the last time it was working properly?
Kindly try the suggested methods below.
Solution
Other options:
Posted on page 5 of this thread by TammyEldredge
* * Refers to Edge legacy, not Edge Chromium. * *
I've been having the same problem and none of the settings changes worked for me.
After much searching, I found these instructions:
https://www.windowscentral.com/how-prevent-loading-microsoft-edge-processes-startup-windows-10
I am no longer plagued by Microsoft Edge.
Posted by JeremiahV on 13 January.
Edge version 97.0.1072.62 contains the fix and will be installed per your regular update policies over the next day or so. If you'd like to force the update immediately, you can head over to edge://settings/help in the address bar or Settings > About Microsoft Edge and trigger the update manually.
If you've made any registry edits or GPO changes as mitigation, you can revert those after the update!
Posted by AmyTorres2 on Feb 3...
I still have to make sure that my cursor is not hovering over the center of the screen, where one of the pre-login screen messages is, when I click it to bring up the login screen, as that does open Edge.
9. Added on 5 March 2022.
When waking up the computer from sleep...
Press any key on your keyboard, EXCEPT the 'space bar', seems the space bar opens up Edge by default from sleep.
On page 10 of this thread by Jane2022.
10. Added on 3 April 2022. From Kingianum on page 12.
In the end this is what did the trick:
Go to Lock Screen Settings. In the Background drop down, select either Picture or Slideshow. Choose your picture.
Done.
The Windows Spotlight option is what starts up Edge.
Sincerely
John DeV
Independent Advisor
Edit: Community volunteers also contributed to this answer.
* * Mod note: Refers to Edge legacy * *
Hi Joseph ~
Give it a try. I hope it works for you too!
~ Tammy
