How do I disable Microsoft Edge from opening when I start my computer?
2020-10-08T21:11:22+00:00
How can I stop Microsoft Edge from starting every time I restart my computer?
**Updated for clarity**
Microsoft Edge | Open the browser | Windows 10
John DeV 169.9K Reputation points Independent Advisor
2020-10-08T21:17:01+00:00
Hello JosephPare1,
I'm John an Independent Advisor and a Microsoft user like you. I'll be happy to assist you today. I understand you have a problem with Edge opening automatically at startup. Did you made any changes recently? When was the last time it was working properly?
Kindly try the suggested methods below.
Solution
  1. Go to Start  > Settings .
  2. Select Accounts > Sign-in options.
  3. Turn off Automatically save my restartable apps when I sign out and restart them when I sign in
Other options:
  1. Press Start then search Settings > Apps > Startup > Please try to turn everything off. Check if Edge will no longer start automatically.
  2. Kindly check if you're using Windows Spotlight in your lock screen. Once you click Edge, it will automatically search for any word that you click after unlocking the device. It's recommended to change your lock screen settings.
  3. Added by Moderator on 28 Jan 2022. Edge > Settings > System and performance > Startup boost > turn off.
  4. Added by Moderator on 9 Feb 2022.
Posted on page 5 of this thread by TammyEldredge
* * Refers to Edge legacy, not Edge Chromium. * *
I've been having the same problem and none of the settings changes worked for me.
After much searching, I found these instructions:
https://www.windowscentral.com/how-prevent-loading-microsoft-edge-processes-startup-windows-10
I am no longer plagued by Microsoft Edge.
  1. Added on 12 Feb 2022.
Posted by JeremiahV on 13 January.
Edge version 97.0.1072.62 contains the fix and will be installed per your regular update policies over the next day or so. If you'd like to force the update immediately, you can head over to edge://settings/help in the address bar or Settings > About Microsoft Edge and trigger the update manually.
If you've made any registry edits or GPO changes as mitigation, you can revert those after the update!
Posted by AmyTorres2 on Feb 3...
I still have to make sure that my cursor is not hovering over the center of the screen, where one of the pre-login screen messages is, when I click it to bring up the login screen, as that does open Edge.
9. Added on 5 March 2022.
When waking up the computer from sleep...
Press any key on your keyboard, EXCEPT the 'space bar', seems the space bar opens up Edge by default from sleep.
On page 10 of this thread by Jane2022.
10. Added on 3 April 2022. From Kingianum on page 12.
In the end this is what did the trick:
Go to Lock Screen Settings. In the Background drop down, select either Picture or Slideshow. Choose your picture.
Done.
The Windows Spotlight option is what starts up Edge.
Sincerely
John DeV
Independent Advisor
Edit: Community volunteers also contributed to this answer.
2022-01-13T23:25:34+00:00
2022-01-11T13:56:50+00:00
* * Mod note: Refers to Edge legacy * *
Hi Joseph ~
Give it a try. I hope it works for you too!
   ~ Tammy
109 additional answers
    2020-10-10T13:57:31+00:00
    Hi there,
    I am a curious kid, (my name explains who I am), and I would like to say, there is one more way I know.
    1. Open Task Manager via start or shortcut "Ctrl+Shift+Esc"
    2. Click on more details on the bottom (only if seen, if not you're good)
    3. Naviguate to the Startup tab on the top
    4. Search for Microsoft Edge, right click it and hit Disable.
    ( Just saying )
