Extensions for Microsoft Edge | Microsoft Edge for iOS
2020-05-09T11:35:11+00:00
I was wondering if extensions is available for Microsoft Edge on iOS? (specifically on iPad). Or is it only available for Windows 10 laptops?
/ tozizenon
Microsoft Edge | Browser extensions | iOS
2020-05-09T11:40:04+00:00
Hi tozizenon,
I am Aster, an Independent Advisor and I'm here to help you with your problem.
Thanks for the query, unfortunately, the extensions are only available for Windows 10 and not on iPad. Thank you.
6 additional answers
    2021-06-07T18:29:29+00:00
    I have the iPad Pro 2021, and it is on iPadOS technically, however it makes no difference since it uses the standard IOS app, not a separate iPadOS one.
    2021-06-07T18:31:43+00:00
    I have the m1 iPad Pro, but am also a developer myself, the extension support is strictly platform related and has nothing to do with the processor, Safari, in both old and new iPads has extension support, it is just something that needs to be programmed in, and in this case it wasn't. With that said, as a user myself, I would love extension support.
