Edge keeps freezing up.
2021-01-05T06:28:52+00:00
My Microsoft Edge browser keeps freezing up. I have tried all the suggested solutions with no success. I like the design and functionality offered by Edge, but will change to Firefox until I get a notice that Microsoft has fixed the problem with Edge freeze ups.
Microsoft Edge | Browser crashes or stops working | Windows 10
    2022-02-08T00:22:12+00:00
    I had previously experienced this issue with Edge in Win 10. I had hoped with Win 11 Microsoft had resolved the issue. Apparently not. In addition when I launch Edge I get 2 sets of start up pages. Whatever I select for a start up tab opens 2 tabs when I launch Edge. Until Microsoft sorts out Edge I am going to be using Chrome. It is very annoying.
    2022-02-08T00:23:21+00:00
    Having to use such a work around is unacceptable. I shall simply be using Chrome until Edge is fixed.
    2022-02-08T03:56:53+00:00
    Thank you, that's not a long term solution but, better than having to end task and start over. I really don't want to change browsers again, they all seem to have their own issues.
    2022-02-09T00:42:42+00:00
    Thanks Kandyman! It seems to be working for the time being. And thanks for the quick response.
    2022-02-09T04:00:21+00:00
    The problem for me is that when Edge freezes, oftentimes, my usb mouse and usb keyboard are nonresponsive, so i can't open Task Manager. Then i have to do a hot shutdown by holding the power button until the pc shuts down. Then i restart the pc. Since it kept freezing, i switched over to Firefox for the time being until MS gets around to fixing it.
