Edge and Chrome freezes while browsing making Windows not responsive for 1 minute follow by Windows explorer behave strangely
2020-12-12T02:31:53+00:00
As title says, my Windows behave strangely every now and then. When browsing, it may freeze for a minute or so follow by making I can't open everything. If I'm lucky enough, this issue last for 2 hours, if not, I need to restart the PC. Photo below tells it all.
Microsoft Edge | Browser crashes or stops working | Windows 10
    2021-09-04T07:43:39+00:00
    Well, mine after replace to newer harddisk(got 2 HDD clocked 20 years) such freezing issues are lesser(and happens to loading new webpages that I never visit), but now I may be "losing" the new HDD for no reaon, need to turn off power, disconnect, restart Windows, shutdown, connect back everything and problems solved. This happens after I updated the latest Windows Updates.
    2021-09-06T07:04:16+00:00
    Thanks it works!
    2021-09-26T20:23:07+00:00
    Also having this same issue. I'm running a Dell Inspiron which did get an Intel Grapucs Command Center update the same day. Firefox is working great. Any ideas appreciated!
    2021-09-27T04:16:41+00:00
    After Edge updated, I was having the freezing issues still. I checked and found Hardware Acceleration was turned on again. I turned it off and no problems.
    2021-09-27T04:17:30+00:00
    Try doing the fix that was earlier in the comments. Go into your settings for Edge or any chrome based browser, turn off hardware acceleration. It seems to be a fix that helps a lot of people.
