Managing profiles and sync in Microsoft Edge on Windows 10
Hi edge experts,
I use a MS account to sign into Microsoft products, but I use only in my laptop system. How to stop sync when not needed?
Thank you,
Nithin. R
Dear Jen,
There is no 'Resume sync' button in Windows-11
There is NO toggle to actualy stop syncing in Edge. You can select what to sync but that does not stop it.
To actualy turn off sync for a profile
1: Open MS Edge while you signed in with MS Account
2: Type to address bar without " marks: " edge://sync-internals "
3: Click on: " Disable Sync (Clear Server Data)"
4: Your profile will show "not syncing", means the deletion was successful. Log out of your profile and tick the box to delete everything, during the logout.
With this method, all bookmarks, history, passwords, extension etc. were deleted from the cloud and locally as well.
Yeah - total data theft. There is no warning they are going to steal data from your chrome browser. Nor is there any way to get it back.
Excellent, I can confirm this still works right now. Although initially there is no "Edge" subkey under Microsoft, you can just create one.
I don't use the Edge piece of sheet at all, but I just wanted to check the functionality of a problematic site that seemed to not be working fully in my usual 2 browsers. All of the sudden it started trying to sync and wouldn't stop prompting me to login to my MS account and I was like , <removed>
But it wouldn't let me close the login prompt and wouldn't let me click anywhere else on the page. Edge is literally like a virus.
<profanity removed>
