Installing or updating Microsoft Edge on Windows 10
My question is very simple that is HOW DO I REMOVE BING AS SEARCH ENGINE FROM MICROSOFT EDGE.
Please, please and please give me a simple and direct answer or solution and not by "beating around the bush"
I am getting very fed up with Bing appearing as my search engine. I never as for it but how come Bing came in as my search engine. There are thousands if not millions that HATE Bing. Why is it still there, JUST REMOVE IT OUT FROM THE WEB or whatever permanently.
PLEAE HELP ME TO REMOVE BING IN A VERY SIMPLIFIED STEPS!
Assuming you're using the Chromium-based Edge, open Edge settings [click ⋯ (Settings and more) > Settings], then choose Privacy, search and services > Address bar and search > Manage search engines. You should see Google as an option. Click the ellipsis (three dots) at the right end of the entry and choose Make default.
Edited to reflect changes in the UI since the answer was posted
I tried this as well. only when i click on the elipse is only shows edit and not make as default. also i want to REMOVE BING FROM MY COMPUTER
On the "Address bar search engines", it automatically makes Bing the search engine and will not let me change it. It has a little red circle with a line through it when I try to click on it to change it. The drop down will not drop down. Underneath the drop down box, it does give me a list of other search engines but clicking on them does nothing. Bing has hi-jacked my search engine and I hate it!!! Please help!
Is your computer perhaps running Windows 10S? Changing the default search provider is not allowed. https://support.microsoft.com/en-us/help/4020089/windows-10-in-s-mode-faq
Otherwise, someone else - the IT department at school or work, for example - can prevent changes to the default search provider. If this is the case, you will see Managed by your organization at the foot of the Settings and more menu. Click on that and then on the link at the end of the explanation to see what they are managing.
Either way, this only means that searches from the New Tab Page will be carried out by Bing. You could set the Home page to the home page of your favourite search engine:
Settings and more > Settings > Appearance > Show home button.
Well that sucks!!
Yes it is Windows 10S.
Thank you for answering my question.
