How do I stop Edge from automatically opening on start up? Windows 10 Pro 64 20H2
2020-11-12T00:43:35+00:00
Edge is opening EVERY TIME I REBOOT!
Insidiously it is absent from all STARTUP control systems so we CAN'T STOP it.
Does congressional investigations of unfair trade practices do nothing?
How can microsoft be so trumpianly abusive?
Microsoft Edge | Open the browser | Windows 10
2022-01-13T23:24:24+00:00
Edge version 97.0.1072.62 contains the fix and will be installed per your regular update policies over the next day or so. If you'd like to force the update immediately, you can head over to edge://settings/help in the address bar or Settings > About Microsoft Edge and trigger the update manually.
If you've made any registry edits or GPO changes as mitigation, you can revert those after the update!
101 additional answers
  1. Drew - 810 Reputation points
    2022-04-07T08:55:23+00:00
    "You can search for it (Task Mgr) in the task bar."
    Just to clarify, suppose technically speaking it is "in the Task Bar, but actually or more specifically, in Windows 11 it is found by Rt Clk the Win logo or using Win+X. Unless, of course, one has it pinned to the Task Bar.
    In Win10 it is on the task bar's Rt Clk menu.
    Cheers,
    Drew![](https://learn-attachment.microsoft.com/api/attachments/636da5fb-edc7-4dd0-916b-db155c9d9531?platform=QnA
