Launching Microsoft Edge on Windows 10
Edge is opening EVERY TIME I REBOOT!
Insidiously it is absent from all STARTUP control systems so we CAN'T STOP it.
Does congressional investigations of unfair trade practices do nothing?
How can microsoft be so trumpianly abusive?
Edge version 97.0.1072.62 contains the fix and will be installed per your regular update policies over the next day or so. If you'd like to force the update immediately, you can head over to edge://settings/help in the address bar or Settings > About Microsoft Edge and trigger the update manually.
If you've made any registry edits or GPO changes as mitigation, you can revert those after the update!
You're welcome. As for what you last said, if you can go to Win11, that would be brilliant.
Is it listed under Processes?
Certainly, representing & involving 1.3+ billion End Users from around the world.
And we can agree to disagree, as I personally believe the implications of the previous 2 comments are inaccurate or based on falsehoods... they don't apply to any reality.
Also, a reminder, Edge is, indeed, Windows Default web browser... it is part of the OS, now.
Try closing all instances of Edge & then Reboot. Do active Edge windows you HAD reopen by themselves?
Cheers,
Drew![](https://learn-attachment.microsoft.com/api/attachments/d75f9f2d-bc6f-44b1-978c-07d1d602c446?platform=QnA![](https://learn-attachment.microsoft.com/api/attachments/c65a8301-61df-451d-82f4-c5cd3b2edfef?platform=QnA
Thank you will try this.
