Managing bookmarks, browsing history, and downloads in Edge on Windows 10
I cannot understand why Microsoft have limited the number of Quick Links able to be displayed on the home page to eight. I have been using Firefox for several years and found that with up to 16 available, I can cover the the sites I uses regularly (although I don't use all 16).
To not even, say, allow an option to increase the number seems to be unnecessarily controlling/limiting.
I have submitted this as formal feedback, I hope more people do so.
I can see why you would need them. You shoudl send feedback so they understand your sistuatoin. How would more than 8 quik links fit on one page though. I tis kinda of a clutter. Hope they figure that out.
Shawn: as you have replied to my post- if you actually read my post I did send formal feedback, using the Microsoft tool.
Was this added some where? I cannot see it.
As mentioned in the Thread, it has been approved to be added and is in testing.
Yes, it is added but not anyone in those channels can see them since it is a target rollout.
I think this is the solution and this has answered the original post.
THankyou
I downloaded Dev a couple days ago. I see 10 links on the opening page.
That's 2 more than on my old edge.
I can't figure out any way to add more on Dev.
Guess I wasn't included in the target rollout.
That's great you see 10 quick links, maybe they are testing if there is any issues with the different numbers of quick links in edge at first.
Maybe try Canary as well?
I don't know if there is a way to control the numbers. Maybe send feedback about that?
