Launching Microsoft Edge on Windows 10
Since that last update, my home page isn't showing up every time I start up Microsoft Edge.
And this is my settings for Edge:
Can you tell me why this happening?
This is a bug affecting a few users. The Edge team reported on 29 November::
| This is a known issue and is fixed in 97.0.1057.0 but not quite moved up to Stable yet. Our Insiders who've had the same thing happening have reported it resolved, so you're welcome to give anInsider builda try if you'd like (Canary and Dev have the fix.) Or, I'll check back in with you after that build is in Stable and make sure the fix is working for you! |
Microsoft Edge Version 96.0.1054.34 (Offizielles Build) (64-Bit) - Microsoft Tech Community
Alexandra doesn't make clear whether this fix is incorporated into one of the builds 1055-1057 or into the major update to Edge 97, but if it's the latter, the the expected Stable release date for Edge 97 is next month:
| Version | Release status | Beta Channel <br>Release week | Stable Channel <br>Release week |
| 97 | Released <br>Version | 01-Dec-2021 <br>97.0.1072.21 | Week of 06-Jan-2022 |
[https://docs.microsoft.com/en-us/deployedge/microsoft-edge-release-schedule#release-schedule]
Yes, I did, still didn't work though.
So, the fix will be fixed after the date January 06, 2022?
No guarantees, sorry - there may still be a specific reason why your particular Edge installation is having this problem. That's why it's really helpful to submit feedback, to help the engineers also cater for 'edge cases' - no pun intended.
I've sent feedback, hopefully, it'll be picked up.
Go back to Edge Settings > Start Home and New Tabs, change Start Home and New tab setting to New Tab page.
Close Edge, reopen, take a full page screenshot of the and post it back.
