Microsoft Edge not showing my homepage
2021-12-05T22:19:58+00:00
Since that last update, my home page isn't showing up every time I start up Microsoft Edge.
And this is my settings for Edge:
Can you tell me why this happening?
Microsoft Edge | Open the browser | Windows 10
2021-12-07T09:45:42+00:00
This is a bug affecting a few users. The Edge team reported on 29 November::
This is a known issue and is fixed in 97.0.1057.0 but not quite moved up to Stable yet. Our Insiders who've had the same thing happening have reported it resolved, so you're welcome to give anInsider builda try if you'd like (Canary and Dev have the fix.) Or, I'll check back in with you after that build is in Stable and make sure the fix is working for you!
Microsoft Edge Version 96.0.1054.34 (Offizielles Build) (64-Bit) - Microsoft Tech Community
Alexandra doesn't make clear whether this fix is incorporated into one of the builds 1055-1057 or into the major update to Edge 97, but if it's the latter, the the expected Stable release date for Edge 97 is next month:
Version Release status Beta Channel <br>Release week Stable Channel <br>Release week
97 Released <br>Version 01-Dec-2021 <br>97.0.1072.21 Week of 06-Jan-2022
[https://docs.microsoft.com/en-us/deployedge/microsoft-edge-release-schedule#release-schedule]
44 additional answers
    2021-12-06T22:31:19+00:00
    Having same problem as Damouk24. I carefully followed the suggested fix and all went well until I clicked "Modify". Clicked "yes" and then "repair". Was given a choice that either uninstalled Edge or downloaded a new copy. D'loaded a new copy and restarted. No difference. Nowhere did I get options to go to my startup page rather than the Edge horror.
    Help appreciated
    2021-12-06T23:02:30+00:00
    Hi Damouk24 -
    Thanks for the update and I apologize but it seems that I ran out of ideas, maybe someone has a better resolve.
    Regards,
    Jerico T.
    2021-12-07T00:13:25+00:00
    Hope that someone will give me a resolve then and very soon.
  4. Sumit 44,436 Reputation points Volunteer Moderator
    2021-12-07T02:59:38+00:00
    Do you have CCleaner or Avast cleanup utility installed?
