Microsoft Edge not showing my homepage
2021-12-05T22:19:58+00:00
Since that last update, my home page isn't showing up every time I start up Microsoft Edge.
And this is my settings for Edge:
Can you tell me why this happening?
Microsoft Edge | Open the browser | Windows 10
2021-12-07T09:45:42+00:00
This is a bug affecting a few users. The Edge team reported on 29 November::
This is a known issue and is fixed in 97.0.1057.0 but not quite moved up to Stable yet. Our Insiders who've had the same thing happening have reported it resolved, so you're welcome to give anInsider builda try if you'd like (Canary and Dev have the fix.) Or, I'll check back in with you after that build is in Stable and make sure the fix is working for you!
Microsoft Edge Version 96.0.1054.34 (Offizielles Build) (64-Bit) - Microsoft Tech Community
Alexandra doesn't make clear whether this fix is incorporated into one of the builds 1055-1057 or into the major update to Edge 97, but if it's the latter, the the expected Stable release date for Edge 97 is next month:
Version Release status Beta Channel <br>Release week Stable Channel <br>Release week
97 Released <br>Version 01-Dec-2021 <br>97.0.1072.21 Week of 06-Jan-2022
[https://docs.microsoft.com/en-us/deployedge/microsoft-edge-release-schedule#release-schedule]
44 additional answers
    2021-12-05T23:49:56+00:00
    Hi Damouk24 -
    I'm Jerico T., I understand that you're having some issues right now and I'd be more than happy to help you today.
    If I may ask, did you mean the last update of Microsoft Edge or the latest Windows Update? Let's try to perform the steps below.
    1. Open settings by pressing windows key + I
    2. Select Apps
    3. On the left pane, select Apps & features
    4. You'll see the list of your apps, look for Microsoft Edge
    5. Click Microsoft Edge and select Modify
    6. A windows will pop-up, click Yes
    7. Click the Repair button and follow the on-screen steps
    8. Restart your computer if necessary and check if the issue still persist
    Feel free to reach back if you need any further assistance.
    Hope this help. Have a good day.
    Thank you,
    Jerico T.
    2021-12-06T00:44:37+00:00
    Since the last Microsoft Edge Update. And your instructions hasn't worked.
    2021-12-06T03:24:13+00:00
    Hi Damouk24 -
    Thank you for your response. I see, then please try to click the link below then scroll down and perform the steps proved on how to reinstall Microsoft Edge.
    https://support.microsoft.com/en-us/microsoft-e...
    Regards,
    Jerico T.
    2021-12-06T08:19:06+00:00
    That was the same as the previous instructions. It still, like before, hasn't worked.
