Other issues or features related to Microsoft Edge on Windows 10
Hi, I hope somebody can help. My Windows 10 laptop has installed the new Edge Browser for 2020. It is Edge number 80.361.66, 64 bit. On the old Edge I can go to the more icon (....) at the top right, then More Tools, then Pin To Start. Now on this new Edge there is no Pin To Start. How can I pin a web page to my Start Menu. If I cannot pin a web page to my Start Menu, what's really the use of the Start Menu. I have always had folders on my Start Menu with pages pinned. Now I can't. Can anyone help me? Cheers.
I have figured out a way to pin a site to Start. See the GIF - requires you to pin to the taskbar first. unfortunately, the update to Edge cannot be uninstalled.
First pin the site to the task bar via Edge's three dot menu/More tools/Pin to taskbar then right click on the new icon that it created on the taskbar, right click on the menu item above "Unpin from taskbar" and choose "Pin to start". You can then unpin the icon from the taskbar.
Thank you for your help
I add site to my task bar, then right click on icon on task bar, then right click to start menu. New tile shows up on start but does not work.
How do i fix?
It worked Thank You.
OMG!!!!!!!!!!!!!!!!!! THIS WORKS!!!!!!!!!!!!!!!!!!!!!!!!!!!
