Other issues or features related to Microsoft Edge on Windows 10
Hi, I hope somebody can help. My Windows 10 laptop has installed the new Edge Browser for 2020. It is Edge number 80.361.66, 64 bit. On the old Edge I can go to the more icon (....) at the top right, then More Tools, then Pin To Start. Now on this new Edge there is no Pin To Start. How can I pin a web page to my Start Menu. If I cannot pin a web page to my Start Menu, what's really the use of the Start Menu. I have always had folders on my Start Menu with pages pinned. Now I can't. Can anyone help me? Cheers.
I have figured out a way to pin a site to Start. See the GIF - requires you to pin to the taskbar first. unfortunately, the update to Edge cannot be uninstalled.
Thanks so much!! It worked! I'm assuming somewhat the same process for Google Photos.
This is so annoying not to be able to pin tiles to my page. Hope someone finds a workaround soon.
I see where you answered the question, "Can't pin links to Start on Edge upgrade 2020" but I don't see your answer? And I would like to fix this problem too. Thanks
Click on page you want, than (...) at top right corner. Click (more tools), pin to task bar. Once you see the page icon in the task bar, right click it, than right click page again. It will say pin to start there.
