Other issues or features related to Microsoft Edge on Windows 10
Hi, I hope somebody can help. My Windows 10 laptop has installed the new Edge Browser for 2020. It is Edge number 80.361.66, 64 bit. On the old Edge I can go to the more icon (....) at the top right, then More Tools, then Pin To Start. Now on this new Edge there is no Pin To Start. How can I pin a web page to my Start Menu. If I cannot pin a web page to my Start Menu, what's really the use of the Start Menu. I have always had folders on my Start Menu with pages pinned. Now I can't. Can anyone help me? Cheers.
I have figured out a way to pin a site to Start. See the GIF - requires you to pin to the taskbar first. unfortunately, the update to Edge cannot be uninstalled.
Seriously? That's pretty much a useless response. I think the best solution is to buy a Mac.
thanks Sumit! I actually tried installing the site as an app. I thought it didn't work cz usually when there is a new app installed, it shows up first in the 'recently added' list in the Start menu. it wasn't there. after reading your solution, i checked my apps and it was just there. so then the usual right clicking and choose pin to start. AWESOME! 🤘��
I have the same problem and it started with the new updates in June 2020 ..... I may as well use google chrome instead
