Other issues or features related to Microsoft Edge on Windows 10
Hi, I hope somebody can help. My Windows 10 laptop has installed the new Edge Browser for 2020. It is Edge number 80.361.66, 64 bit. On the old Edge I can go to the more icon (....) at the top right, then More Tools, then Pin To Start. Now on this new Edge there is no Pin To Start. How can I pin a web page to my Start Menu. If I cannot pin a web page to my Start Menu, what's really the use of the Start Menu. I have always had folders on my Start Menu with pages pinned. Now I can't. Can anyone help me? Cheers.
I have figured out a way to pin a site to Start. See the GIF - requires you to pin to the taskbar first. unfortunately, the update to Edge cannot be uninstalled.
Thanks Butterfly ,,, awesome .. Cheers.
Hi Summit. Thanks for all your awesome advice on here.
It's now February 2021. I have now noticed that Edge has a great way now of putting web pages on the Start Menu. The three little dots ... , More tools, Pin to Start.
All works well now. However I don't like the way it puts the web pages in my Apps list as an App.
Take care . Be safe. Cheers.
Hi
I have the Edge Icon on my Task Bar and when I right click there is a list of 'recently opened' and, in some cases, pinned sites. But not all sites will pin to this facility. Even if I keep opening them they do not appear as the 'recently opened''. Any clues on why this would be???? Or how I can ensure they do pin.
Thanks.................
