2020 Edge cannot pin web pages to Start Menu ????
2020-03-20T05:22:18+00:00
Hi, I hope somebody can help. My Windows 10 laptop has installed the new Edge Browser for 2020. It is Edge number 80.361.66, 64 bit. On the old Edge I can go to the more icon (....) at the top right, then More Tools, then Pin To Start. Now on this new Edge there is no Pin To Start. How can I pin a web page to my Start Menu. If I cannot pin a web page to my Start Menu, what's really the use of the Start Menu. I have always had folders on my Start Menu with pages pinned. Now I can't. Can anyone help me? Cheers.
Microsoft Edge | Other | Windows 10
SD - IA 179.6K Reputation points Independent Advisor
2020-03-20T08:33:59+00:00
I have figured out a way to pin a site to Start. See the GIF - requires you to pin to the taskbar first. unfortunately, the update to Edge cannot be uninstalled.
63 additional answers
    2020-12-10T04:01:21+00:00
    I had the same problem. I did this.
    Right click on the taskbar button
    Right click on the name of the webpage.
    Click on 'Pin to Start'.
    Hope it helps!
    Dennyboy.
    2020-12-10T16:38:11+00:00
    Thank you, DennyBoy51. That worked!
    2020-12-17T22:57:00+00:00
    Hi Sumit,
    I get as far as pinning it to start as in your GIF - but the link that ends up on start has no icon, a weird name and does not open anything. I really loved your answer - it just doesn't give the desired result. But thank you for trying.
    2020-12-17T22:59:48+00:00
    Yep. I am a Microsoft fan and have not wanted to switch to another browser. Now, it might have to happen.
