Managing tabs, address bar, and search settings in Edge on older Windows versions
I used to have tabs/sidebar on far right, now I do not!
How can I repair EDGE, or what needs to be repaired?
Thanks!
CarrmasDad
Is it possible to enlarge the DARK words etc.
and change the size and tint of the light words etc.?
I answered a similar question a couple of weeks ago: Making all text on Edge webpage darker - Microsoft Community
You might find the solution useful.
I opened Settings but I did not see APPEARANCE!
The settings navigation pane is hidden if the window is too narrow. You should see a 'hamburger' icon ≡ to the left of the Settings heading; a click on it should then reveal the settings menu. Or just make the window a bit wider.
Hi CarrmasDad,
They must have different settings in the Windows 7 edition, if you click the 3 dots at the top right of Edge, on the resulting menu, near the bottom, is there the 'Show Sidebar' option on that menu?
HI DAVE,
I did get it resolved, I did turn it on and checked it out, no side bar, so I did it again after REBOOTING the computer, it worked like a dream!
Many Thanks
How can I change the text color and size that show in several places? Do you want me to start another thread?
CarrmasDad2
Hi CarrmasDad2,
Where do you want to change the text color and size in Edge?
