Microsoft Edge shows No Network Connection when attempting to Sign in
2021-10-07T15:42:32+00:00
I cannot sign in to my Microsoft account in Edge, but I can browse. What to do now?
[Original Title: Microsoft Edge]
Microsoft Edge | Profile, sync, and sign in | Previous Windows versions
2021-10-08T11:49:40+00:00
There was a bug in Windows 7 that surfaced some weeks ago. Ensuring that all Win7 updates were applied solved this problem for at least some affected users.
Reza-Ameri 45,896 Reputation points Volunteer Moderator
2021-10-07T17:25:48+00:00
Are you using any VPN or Proxy?
Did you add any extensions?
Try close the Microsoft Edge and re-open it and try again.
4 additional answers
    2021-10-09T17:45:08+00:00
    Hi, Thanks. Did it already and the team replied. And waiting for the solution.
    2021-10-22T16:35:48+00:00
    Hi, thanks all. My problem is solved with the latest update.
