Managing profiles, sync settings, and sign-in options in Edge on older Windows versions
I cannot sign in to my Microsoft account in Edge, but I can browse. What to do now?
[Original Title: Microsoft Edge]
Make sure report this issue using the feedback option in the Microsoft Edge.
Take a look at How to Report a Feedback/Bug to Microsoft Edge’s Team? - Microsoft Community.
There was a bug in Windows 7 that surfaced some weeks ago. Ensuring that all Win7 updates were applied solved this problem for at least some affected users.
Are you using any VPN or Proxy?
Did you add any extensions?
Try close the Microsoft Edge and re-open it and try again.
Hi, Thanks. Did it already and the team replied. And waiting for the solution.
Hi, thanks all. My problem is solved with the latest update.
