Troubleshooting website display or functionality issues in Edge on Windows 10
Starting this morning, every time I close Edge and reopen it, it doesn't remember any of my login so I have to login every time to every website.
I confirmed my setting is set to NOT clear cookies when I close my browser and it has always been this way. I have never had this issue until this morning.
A features update was installed this morning and that's when this problem started. Is there a bug with this update? I'm running Windows 10 and Edge Version 86.0.622.38. As you can imagine, it is quite annoying having to login to every time to every website.
Update-There must be a bug because other people on Reddit are starting to report the same issue.
Hi folks,
The original topic of this thread (Microsoft Edge not remembering logins) has been resolved. Make sure you've updated to the latest version of Edge to get the fix! I'm locking this thread as it is becoming difficult to moderate and troubleshoot individual issues, and this thread has turned in to a catch-all for all password issues.
If you are still seeing issues with Edge not remembering passwords and all other programs are remembering your logins as expected, please start a new thread so we can help you individually.
If you are seeing system-wide issues with passwords being saved:
• Check your Windows version to confirm if you are on Build 19041.173 or later
• If yes, reference this troubleshooting document Outlook and other apps won't remember password after Windows Updates - Outlook (microsoft.com) Note that this is a workaround until this Windows issue is patched.
-Alex
edge just updated itself to Version 86.0.622.69 & it still won't save my web userids & passwords
Microsoft Edge is up to date.Version 86.0.622.69 (Official build) (64-bit))
Yup; same here. Nothing has changed. Still fails the same as ever.
so this morning, my edge web userids & passwords just reappear, & i can use them again. go figure why.
BUT many sites still LOGGING ME OUT AND NOT REMEMBERING USER NAME.
OK its 11/16 and we've had several Edge updates .69 being the latest AND YET
while some websites do remember the user name and of course the password... MANY others are still logging us out and NOT remembering squat... except for passwords that is
