How to prevent video autoplay in Chromium Edge
2020-01-18T12:12:20+00:00
Hi
I've upgraded to chromium edge but now videos are autoplaying again. I had this disabled on classic Edge but can't work out how to do this on the new version.
I've set "Media autoplay" to "Limit" in the "Site Permissions" section of settings but this doesn't seem to have had any effect at all (yes, I've restarted Edge / Windows).
I had also had this problem with dev / beta builds of Edge but hadn't got around to chasing it up until it became my primary browser.
In particular it's annoying on the MSN new pages linked to from the new tab page in Edge when they all have autoplaying video.
Microsoft Edge | Audio and video playback | Windows 10
2020-02-12T09:55:30+00:00
Why isn't there an option called "Block"?
You'll probably find that the block option has to be enabled. Copy the next line into the address bar and press Enter:
edge://flags/#edge-autoplay-user-setting-block-option
Once this flag is enabled, you should see Block on the autoplay options menu.
2020-05-22T12:58:37+00:00
Hi MichalTadeas and thanks for reaching out. My name is Joseph. I'm an independent advisor. I'll be happy to help you out today.
I would suggest you refer to the below steps and check if it helps to resolve the issue.
  1. Open Microsoft Edge.
  2. Copy edge://flags/ and paste it to the browser's address bar.
  3. Type 'Show block option in autoplay settings' and set it to 'Enable'.
  4. Copy edge://settings/profiles and paste it to the browser's address bar.
  5. Type 'Media autoplay' click it.
  6. Set it to 'Block'.
  7. Restart your computer, and when it boots up, check to see whether or not the problem has been resolved.
I hope this helps. Feel free to ask back any questions and let me know how it goes.
Thank you!
SD - IA 179K Reputation points Independent Advisor
2020-02-12T07:27:12+00:00
Hi Ash,
I am Sumit, an Independent Advisor and a 3 year Windows Insider MVP here to help.
In the new Microsoft Edge, the option of automatic playback is limited.
However, you can install an extension like autoplayblocker from the Chrome web store to disable Autoplay. (You may have to enable extensions from other store).
229 additional answers
    2020-10-10T16:16:07+00:00
    This does not work!! Microsoft, you need to fix this flaw. My suggestion is to let us decide if we want to turn auto play on not whether we want to turn it off!!  Stop trying to control us and let the people decide what they want or need. Leave us alone.
    Go to edge://flags
    Type autoplay
    Change from "default" to "allow" user to set
    Go to settings in edge browser
    Under "autoplay," the options will now be: allow, limit, block
    Pick block
    Viola!!
    I've given you a fix. I completely understand how frustrating it is when browsers don't give you the options you want.  Most of them can be "tweaked" if you are willing to dive into the hidden settings.
    Microsoft has angered me to no end with things like forcing apps I can't uninstall on my Samsung Galaxy phone, and I won't defend them on that point, but when it comes to browsers, there are LOTS of them out there.  You aren't required to use Edge or any other browser for that matter.  No one is trying to control you just because you don't like how their browser works. If you don't like the new Edge browser, just use a different one. It's not that hard....
    Looks like the autoplay-user-setting-block setting has been completely removed from edge://flags as of 10Oct2020 as I sit here TOTALLY FRUSTRATED WITH MICROSOFT for forcing these #$%@^%$@!@#~ videos to be played no matter the "Limit" option or even deselecting Autoplay within the specific video which is supposed to "Limit" future videos from being played.
    Way to go Microsoft.  I'm a former MSFT'ee and have completely stopped using Edge because of one incessant, stupid decision to force videos on their customers.  If I wish to watch a video I WILL CLICK TO WATCH THE VIDEO!!
    I don't need Microsoft dictating I need to watch every video created on the internet.  Stupid, stupid, stupid.
    2020-10-12T05:09:21+00:00
    in Edge 86.0.622.38 does not work either.
