Managing media playback issues and settings in Microsoft Edge on Windows 10
Hi
I've upgraded to chromium edge but now videos are autoplaying again. I had this disabled on classic Edge but can't work out how to do this on the new version.
I've set "Media autoplay" to "Limit" in the "Site Permissions" section of settings but this doesn't seem to have had any effect at all (yes, I've restarted Edge / Windows).
I had also had this problem with dev / beta builds of Edge but hadn't got around to chasing it up until it became my primary browser.
In particular it's annoying on the MSN new pages linked to from the new tab page in Edge when they all have autoplaying video.
Why isn't there an option called "Block"?
You'll probably find that the block option has to be enabled. Copy the next line into the address bar and press Enter:
edge://flags/#edge-autoplay-user-setting-block-option
Once this flag is enabled, you should see Block on the autoplay options menu.
Hi MichalTadeas and thanks for reaching out. My name is Joseph. I'm an independent advisor. I'll be happy to help you out today.
I would suggest you refer to the below steps and check if it helps to resolve the issue.
I hope this helps. Feel free to ask back any questions and let me know how it goes.
Thank you!
Hi Ash,
I am Sumit, an Independent Advisor and a 3 year Windows Insider MVP here to help.
In the new Microsoft Edge, the option of automatic playback is limited.
However, you can install an extension like autoplayblocker from the Chrome web store to disable Autoplay. (You may have to enable extensions from other store).
The thing that bothers me with this issue is we a huge crowd of people have let Microsoft know about the flaws with edge yet they don't seem to be fixing it, i would like to know why this is and when it's going to be fixed as like so many others ill be moving to firefox too, I can stop video autoplay with HTML5 block autoplay extensions but I should not need to, Microsoft is it not the time you got your thumb out of your behind and fix this.
I don't know if Microsoft can effectively block autoplay videos in Edge, especially as Chromium keeps changing things up upstream. Brave (another Chromium based browser) tries harder than Microsoft to block (muted) autoplay and they still get through. Upstream, the chromium developers have stated that muted autoplay videos aren't blocked because advertisers will just use animated gifs more.
Doubtful we will see much traction unless it becomes an accessibility issue.
Joseph, you hit it spot on. Thank you!!
