Opening and reading PDF files in Microsoft Edge on Windows 10
Recently upgraded to the new chromium version of Edge.
The pen & ink settings aren't the same as the last version.
Not able to change the pen color, pen size, select pencil or highlighter if I open a pdf file in edge & try to write on it.
What happened to the choices?
Are there settings to change them?
Do I have to do a screen shot first?
Used to be able to write in real time on an open pdf file.
Does Microsoft look at these posts or are we just complaining amongst ourselves. Microsoft has not responded to this issue at all. I originally purchased the Surface for this function and then they go and disable it!
Meanwhile pen and ink is here, but not usable. I used old Edge to sign PDF contracts, but the new Edge makes my signature shaky so it looks like I'm having Parkinson. Will there be an update or do you have any workaround? In the meantime I work with a free app from the Microsoft store to sign my PDFs, but that's not the way it should be.
