Opening and reading PDF files in Microsoft Edge on Windows 10
Recently upgraded to the new chromium version of Edge.
The pen & ink settings aren't the same as the last version.
Not able to change the pen color, pen size, select pencil or highlighter if I open a pdf file in edge & try to write on it.
What happened to the choices?
Are there settings to change them?
Do I have to do a screen shot first?
Used to be able to write in real time on an open pdf file.
Thanks. Tried Penbook today. Great inking and highlighting capability! However, whatever inking or highlighting I've made... it looks like I cannot save this to the PDF I opened. There appears to have no option to Save Changes to the PDF I opened.
Your alt + shift + 1 does nothing for me on my surface pro 3. I have windows 10 pro.
I second that!
I cant uninstall it. The only option i have is modify. What should i do? Im going nuts!
I have followed the above directions but the "uninstall" button is dull and not available to click.
How do I proceed next to uninstall?
