Opening and reading PDF files in Microsoft Edge on Windows 10
Recently upgraded to the new chromium version of Edge.
The pen & ink settings aren't the same as the last version.
Not able to change the pen color, pen size, select pencil or highlighter if I open a pdf file in edge & try to write on it.
What happened to the choices?
Are there settings to change them?
Do I have to do a screen shot first?
Used to be able to write in real time on an open pdf file.
I am sorry you didn't find the information helpful
the choices are not available in edge chromium.
there are no settings that will enable the feature.
you could take a screenshot and use snip & sketch to annotate it.
Hi MikeDad3611
microsoft is continuing to develop features in Edge chromium, there are a number of features that are yet to be added (or improved)
you can send feedback to the development team (Alt+Shift+I) perhaps they will prioritise this feature if enough users ask.
