Other issues or features related to Microsoft Edge on Windows 10
After adding URL's in IE mode pages it has a expire days of 30. I would like to know how to extend more than 30 days as per InternetExplorerIntegrationLocalSiteListExpirationDays policy.
Please help.
The Guest Profile gets created when you select "Browse as Guest". Nothing unusual there. Your main profile is currently "Profile1". That appears to be the profile that has issues. I would need a copy of that file to help troubleshoot further:
"C:\Users\YourUserName\AppData\Local\Microsoft\Edge\User Data\Profile 1*Preferences*"
If you would like to try one more thing on your own, you could try the PowerShell version of the script and see if the results are any different.
As I mentioned earlier, please open an issue on the IEModeExpiryFix GitHub page. This forum is not the correct place to continue a troubleshooting discussion for that script. Thank you.
Note: If you can't get the script to work correctly, an alternative is to create a small VBS script to launch IE to that government web site. Example: https://github.com/LesFerch/SampleCode/blob/main/VBS-misc/LaunchIE.vbs
Any help with this working would be appreciated
We have 4 Profiles under C:\Users\myusername\AppData\Local\Microsoft\Edge\User Data
looks like Profile1 is the one it is the only one with our email address
have closed all edge using task manager
neither ps1 or vbs works, why?
would send on github but don't know how
Is there any chance your Edge profiles are centrally managed? Is this a company owner computer? The script will not work with managed profiles.
The script will also not work with synced profiles, but it will tell you that in the results display.
Don't think centrally manage unless we use Microsoft to log in
the edge profile is logged out
As mentioned i have Edge profiles
Tried to respond at github, don't know how so i can send preferences
