Keep Edge Up to Date
Drew - 810 Reputation points
2020-07-15T07:08:57+00:00
Please, see the last entry in this thread for what the latest Version of Edge is or should be, to keep yours up-to-date.  Thank-you ��
Cheers,
Drew
Microsoft Edge | Other | Windows 10
  1. Drew - 810 Reputation points
    2023-10-25T06:55:13+00:00
    Version 118.0.2088.69: October 24, 2023
    Fixed various bugs and performance issues. Feature updates
    • Designer (Preview) in the Microsoft Edge sidebar. All Microsoft Edge users with Manifest version 4.8.5 or higher (users can see their version using edge://sidebar-internals), including those that are working on managed devices, can now add the Designer (Preview) app to the Edge sidebar by clicking on the "+" and setting the Designer (Preview) toggle to on. Designer (Preview) allows you to experience the generative AI capabilities offered by Microsoft Designer https://designer.microsoft.com from inside the Edge browser. Designer is a new AI system from Microsoft that generates visual, customizable designs based on your text description and images. This release will be available in English for the following country/regions: Australia, India, New Zealand, South Africa, and the United States*. Administrators can manage sidebar apps including Designer (Preview) icon by using the policies described in Manage the sidebar in Microsoft Edge. The ID for Designer (Preview) app is 2cb2db96-3bd0-403e-abe2-9269b3761041.
    NB: I am in Canada and HAVE Designer❗👍👍
    (Tip: (I) Had to add Designer via the Sidebar Search box by typing Designer as which point it appeared and could be added.)
    Cheers,
  2. Drew - 810 Reputation points
    2023-10-29T03:57:27+00:00
  3. Drew - 810 Reputation points
    2023-11-05T10:01:08+00:00
    Edge is now Series 119
    Version 119.0.2151.44: November 2, 2023
    Stable channel security updates are listed here. Feature updates
    • Compression Dictionary Transport support. A version of the Compression Dictionary Transport feature is available for sites to use by participating in the associated origin trial. If your network uses a middlebox that inspects network traffic and/or you previously encountered issues with the ZSDCH feature, review the Considerations for zstd-based Shared Dictionary Compression for HTTP page which contains updated guidance.
    • Behavioral changes to the beforeunload event. The behavior of the beforeunload event has changed such that calling preventDefault in a beforeunload event handler triggers a confirmation dialog. Setting returnValue to an empty string in a beforeunload event handler no longer triggers a confirmation dialog. This behavior takes effect starting in Microsoft Edge version 119. Administrators can temporarily opt out of this functionality by disabling the BeforeunloadEventCancelByPreventDefaultEnabled policy.
    • Split screen restore improvements. Split screen allows you to simultaneously work on multiple tasks across two, side-by-side screens in one browsing tab to boost your productivity and multitask more efficiently. Now after the browser is restarted and the previous session is restored, the split tab will also be restored.
    • Additional capability to manage sidebar apps. Administrators can utilize the "sidebar_auto_open_blocked" ExtensionSettings policy field to control the auto-open behavior of sidebar apps. For more information, see Detailed guide to the ExtensionSettings policy.
    • Updates to Microsoft Edge enterprise sync settings page. When the ForceSyncTypes and SyncTypesListDisabled polices are used concurrently, the sync settings page (edge://settings/profiles/sync) accurately show the status for each data type.
    Policy updates New policies
    Cheers,
    Drew![](https://learn-attachment.microsoft.com/api/attachments/df788b39-d0e8-403c-b348-555958de2b7d?platform=QnA![](https://learn-attachment.microsoft.com/api/attachments/20937acf-5733-48aa-a011-c2ba9b3065fc?platform=QnA
  4. Drew - 810 Reputation points
    2023-11-09T21:38:56+00:00
    This is as of Nov. 8, 2023.
    November 9, 2023
    Microsoft has released the latest Microsoft Edge Stable Channel (Version 119.0.2151.58) and Extended Stable Channel (Version 118.0.2088.102) which incorporate the latest Security Updates of the Chromium project. For more information, see the Security Update Guide.
    This update contains the following Microsoft Edge-specific updates:
    Cheers,
    Drew![Image](https://learn-attachment.microsoft.com/api/attachments/154c05d1-0394-4fd5-889e-9dd94fcd7977?platform=QnA![Image](https://learn-attachment.microsoft.com/api/attachments/8002e761-19c3-4e93-b40c-c849fa90cc7a?platform=QnA
  5. Drew - 810 Reputation points
    2023-11-18T00:04:03+00:00
