thank for letting us know if you find a fix please up date us
Build 21277 - Hauppauge WinTV software stopped work
After upgrade Win 10 to the latest build, my Hauppauge Win-TV 10 software doesn't work. It will find the TV tuner (Hauppauge HVR-2200), but when I chose any channel, the screen is still black and I've got such info: "Er ror starting Live TV - Device in Use - Check Cortana is not using your Win-TV-HVR-2200 Serial:0". Which is strange, because I have no Cortana (in Polish Windows it's unavailable).
After reinstalling Win-TV 10 it can detect TV tuner, but when scanning channels can't find any except S-Video input (which is active, with cable TV STB connected to). When I chose in, I've got the same info as previously "Er ror starting Live TV - Device in Use - Check Cortana is not using your Win-TV-HVR-2200 Serial:0".
Windows Insider program | Apps on Insider preview
2021-01-14T07:15:12+00:00 -
2021-01-14T12:51:03+00:00 Besure to file a bug report using the Feedback hub app
2021-01-14T12:58:14+00:00 I have done that as have a couple of other people. Not that it seems to matter.
2021-01-14T13:05:06+00:00 Yep, are you all also getting NTFS thorn write errors?They wrote it was fixed it 21292, but its still not..
2021-01-14T13:06:00+00:00 I have done that as have a couple of other people. Not that it seems to matter.
Just keep at it sooner or later it will get address
