I can confirm - finally it works again!
I don't even need to reinstall WinTV, re-search channels only.
Thanks for the confirmation!
-Eddie
After upgrade Win 10 to the latest build, my Hauppauge Win-TV 10 software doesn't work. It will find the TV tuner (Hauppauge HVR-2200), but when I chose any channel, the screen is still black and I've got such info: "Er ror starting Live TV - Device in Use - Check Cortana is not using your Win-TV-HVR-2200 Serial:0". Which is strange, because I have no Cortana (in Polish Windows it's unavailable).
After reinstalling Win-TV 10 it can detect TV tuner, but when scanning channels can't find any except S-Video input (which is active, with cable TV STB connected to). When I chose in, I've got the same info as previously "Er ror starting Live TV - Device in Use - Check Cortana is not using your Win-TV-HVR-2200 Serial:0".
-Eddie
Thanks for reporting that. I can finally update again. Thanks to all involved in getting this fixed.
All is good here to EddieL
Has anyone of you already checked whether our TV tuners are working again in Build 21332?
I can also but had to reboot after first try then all was fine.
