how to resolve " your build of window will expire soon"
2024-09-09T14:00:10+00:00
I have using window 11 home, and I enrolled in window insider preview though beta channel.
my window is activated with a digital license linked to my Microsoft account.
when I switched on laptop (realme book slim) , a window popped up showing message " your build of window will expire on 15 September 2024. you should move to new build as soon as possible".
in window updates section, its showing "you are up to date" that means there is no update available to install.
because I'm not able to upload the images here, I share google drive folder link in which all the images available
(https://drive.google.com/drive/folders/1xBeohp8mbFhRm-XTkJ1cDvhYrA-5MhYW?usp=drive_link)
what should I do to resolve this issue in authentic way asapm
Pauli O 16,380 Reputation points Volunteer Moderator
2024-09-11T19:06:35+00:00
Since you have build 26100.1742 you can leave Insier program by deleting WindowsSelfHost key from registry.
This will lave you rather stable preview of Windows 11 v24H2 which is be released to public later this year, but it will get monthly cumulative updates on patch Tuesdays (Second Tuesday of month).
  1. Open open regedit (push Win key and type regedit).
  2. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsSelfHost
  3. On left panel right click that key and delete it.
  4. Close regedit and restart.
  5. Check your insider settings to see that its out of Insider Program.
  6. Check for updates to get latest C.U.
Edit 30/July/2026
If you are having this issue in 2026, refer to these articles:
https://yourwindowsguide.com/2026/07/this-build-of-windows-will-expire-soon.html
https://learn.microsoft.com/en-us/answers/questions/5940858/windows-insider-preview-certificate-renewal-expira
No. There is no action needed on your side to resolve the “Your Windows Build will expire soon message”this Build of Windows will expire soon” message, since for most of the channels, the Build with updated expiry date isn’t released by Microsoft.
23 additional answers
  1. Pauli O 16,380 Reputation points Volunteer Moderator
    2024-09-22T05:24:53+00:00
    >he build I currently have is Window 11 Pro Insider Preview 26040 Canary Channel
    Unfiortunately you have to build which some users have stuck.
    Announcing Windows 11 Insider Preview Build 26090 (Canary and Dev Channels) | Windows Insider Blog
    • [IMPORTANT NOTE] We are investigating reports that some Windows Insiders in the Canary and Dev Channels are stuck on Build 26040 or Build 23620. The investigation is ongoing, however if you are impacted by this and really want to get onto the latest build in the Canary or Dev Channel today – you can download the latest ISO here and do a clean install and opt your device back into flighting in the Canary or Dev Channels.
    2024-09-22T22:48:59+00:00
    Ahh so it looks like the best bet I can do right now is either do a clean install or wait it out until they fix the issue. I see, thank you!
  3. CrazyKats 19,595 Reputation points Volunteer Moderator
    2024-09-22T23:16:25+00:00
    I would clean install.
    If they were going to fix it it would
    have been done by now.
    2024-09-23T22:12:28+00:00
    I believe I am one of the people stuck on 26040. I tried upgrading in place and the updater just closes with no message or anything. Windows updater still says there are no updates available regardless of which insider branch i switch to.
